Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 79
Thread: rear draws from 4wd action
    330 Post(s)
    I reckon thats a Bargain!
    462 Post(s)
    80kg. Is that right? I thought they would be half that. Bloody look good though. One day I'll do the same.
  4. #13
    Jan 2014
    Hi Mudski. Box was labelled as 75kg net, 80kg Gross... I cant really say that they look a lot different to the more expensive ones that I have looked at in the past. As I said.... I am wrapped..
    2009 GU6 ST-L TB48DE - BUSHMAN FRIDGE, Tigerz-11 Awning, TITAN DRAWERS, TJM Bullbar, Warn Winch (trying to work out what version, and then find a manual)... Not much else YET ! ! ! But a near endless list of wants.
  5. #14
    462 Post(s)
    Nah you should be wrapped. It's come up a treat.
  6. #15
    Expert Malgreen's Avatar
    Yulara
    hey guys i have them installed,, great draws,, had to trim one of the side wings a little but all good, worth every dollar.
    also one of my anchor points is more to one side than the drawers so i had to extend out with a bracket..
    the passenger side wing didnt allow for the pocket so i removed the pocket,
    the fridge slide retaining latch seems a little fragile but if any one has an idea about it please let me know..
    have a look at the pics, i will add the finished pics later..
    this is the anchor point that wasnt right..
    red arrows show where the anchor points are
    this is the little latch that holds the fridge slide in place, looks week in my eyes
    looking down the guts at the runners,, its good and strong
    my fix to get the drawers bolted down on that side,, it arent moving,,lol
    just one thing , are 4 bolt down points strong enough? i am thinking of putting a drop down fridge slide on the drivers side for a fridge
    and using the slide out bit as a table.. would the 4 bolt down points hold the slide in place?
    ok i will put more pics up later when i get back home from work..
    cya all
  7. The Following 2 Users Say Thank You to Malgreen For This Useful Post:
    Avo (10th January 2015), Clunk (7th January 2015)
  8. #16
    Jan 2014
    Bathurst NSW
    I picked up a set of these draws in November fitted them early December, look to be very solid and strong. Have a problem with drivers side wing being a bit to tight, hard to lock into place. Also the lock pin for the fridge slide doesn't seem to line up correctly, but that will be easy fix.not bad for $1095 free shipping
    Had a 1999 GU ST Patrol 4.5L Auto on Dual Fuel ...now have a 2003 GU ST ZD30TD Auto.
  9. The Following User Says Thank You to tallman For This Useful Post:
  10. #17
    Nov 2014
    Hi there, can you please tell me if they rattle when driving.
  11. The Following User Says Thank You to Dapa For This Useful Post:
    megatexture (16th February 2015)
  12. #18
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Look like good bang for buck...
  13. #19
    4wd action superstore has these on special again atm for $895 free delivery.
  14. #20
    462 Post(s)
    Anyone know if these will fit if you have a barrier?
