Page 8 of 8 FirstFirst ... 678
Results 71 to 79 of 79
Thread: rear draws from 4wd action
  1. #71
    Quote Originally Posted by gavsm90 View Post
    does anyone know or have pics of a titan drawer system in a gq patrol with a 80ltr waeco fridge i want to make sure the lid is going to clear the roof part when pulled fully out going by pics in the store web site they dont have a nissan and it looks like the slide wont come out far enough to clear the roof
    @Bloodyaussie has one in the back of his but I'm pretty sure he doesn't have a 80 ltr waeco though
    581 Post(s)
    Not that it's much help but my bro has the Titan and 80l Waeco on the gu, works fine.
  4. #73
    581 Post(s)
    Oops edit, he has a separate slide for it. I would be very weary using their own slider for an 80, hopefully someone else can confirm.
  5. #74
    581 Post(s)
    Pretty sure they don't have a dedicated gq one either and they sell you a Prado one and pray the wings fit in...
  6. #75
    ummmm
    ummmmm
    you don't need 25 post anymore Geez think you'd know of all people
  7. The Following 5 Users Say Thank You to Avo For This Useful Post:
    AB (10th January 2017), Clunk (10th January 2017), MB (10th January 2017), mudski (10th January 2017), Rossco (10th January 2017)
  8. #76
    464 Post(s)
    Yeah the built in slide is very flimsy. Only made from crappy plywood.
  10. #77
    472 Post(s)
    Had to mount it on drivers side. No ways known it would have fitted the Titan slide. Also tried my drop slide and no good a fit either. Ended up buying a Waeco big slide being quite slimeline and even then it was down to the mm's in positioning. Finally made it work to just clear the open barn door yet keep it hard right and also mm's in being able to still open the lid once out versus not smashing the windows out when closing. It can be done, but just use small wood screws for testing 99 times before bolting down :-) !
  11. #78
    May 2017
    I know this is digging a bit of an old thread, but just thought i would give an answer to the OP..
    The Titan drawers while not available in a stacked configuration are easily modified.
    All up from start to finished product installed in the ute, with a whole lot of procrastination involved and a few beers was about 5 hours.
    All thats required
    1 x 4 inch grinder with a 1mm cutting blade
    10 x M8x25mm Stainless Steel bolts and Nylock Nuts
    1 x 17mm Spanner
    1 x 15mm Spanner
    1 x 13mm Spanner
    Allan Keys (preferably to suit an impact driver)
    Some bolts or Tech screws to join the drawers
    If anyone wants more information relating to this shoot me a message.
    Cheers,
    Craig.20170527_093537a.jpg20170527_093542a.jpg20170527_161049a.jpg20170527_093532a.jpg20170527_161058a.jpg
  12. The Following 4 Users Say Thank You to TheChad For This Useful Post:
    AB (29th May 2017), Clunk (29th May 2017), MB (29th May 2017), Mike02Ti (30th May 2017)
  13. #79
    Quote Originally Posted by TheChad View Post
    All thats required
    1 x 17mm Spanner
    1 x 15mm Spanner
    1 x 13mm Spanner
    Cheers,
    Some great work there mate
