28th October 2014, 08:19 PM
Y61 td42
Hi guys. What are the torque specs for Y61 TD42 cylinder head? And the valve clearance.. inlet and exhaust. Please help me guys. Many thanks. Tomboy.
28th October 2014 08:19 PM
30th October 2014, 01:36 AM
Torque is in 2 stages. Stage 1= 39-44Nm. Stage 2= 59-64Nm.
Inlet valve clearances are both same & are 0.030-0.040mm (warm engine)
The Following User Says Thank You to Sharky1 For This Useful Post:
Jorjina Paul (30th October 2014)
30th October 2014, 06:02 PM
valve clearance. Y61 TD42
Thanks heaps. what if the engine is cold? will try that and advise. thanks again.
Sharky1
30th October 2014, 06:19 PM
Sharky1
Your torque specs are wrong mate.
There are 3 different sequences depending on which td42 you have.
TD42
1- 49-59nm
2- 98-108nm
TD42T
1- 39-44nm
2- 59-64nm
3- +110 degrees
TD42Ti
1- 40-44nm
2- 59-63nm
3- +100-120 degrees.
Dales300exc (30th October 2014)
