I just finished fitting a 3" exhaust to my ex telstra rig, stupidly left the passenger canopy door up, connected with a tree and door is very out of shape and fallen off.
I guess it will be more than my excess $600 to fix so I am going to go through insurance, can anybody point me in the right direction to who I need to see for a quote in the brisbane area?
I realise obieco is in tamworth but surely one of the big tray manufacturers or a dealer could do the job.
exhaust sounds awesome so thats a plus but my day could of gone better!
Can you buy a new door and fibreglass the cabin section,
can you post some pics?
You might need a micro switch and a LED light in the cabin to alert you if a door is open
thats not too bad IMO as its not "creased" badly only bent,
I'd gently try and hammer it straight and grab a can paint
to touch up.
I think you could save that door
nice big 6" vice on a solid bench will help,
or a big anvil to tap it back in shape.
very doable with the right gear IMO
How is outer skin held on I cant see and pop rivets
When I bought mine (Rossco body) the pod door alarms would go off on virtually every corner, & I came close to removing them altogether, but before I did so I had a close shave after driving off with one of the doors open, so instead I adjusted the switches for the alarm. Glad I did, impossible to drive off with doors open now, with a buzzer screaming at me & a red light showing on the dash.
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
