Yendor
Hey mate.
I'm guessing you don't need to worry about the wiper motor self parking??
Connect the fuse holder with the 20amp fuse to the positive post of the battery. Run wire from fuse to switch then to wiper motor.
In the attached photo you will see the 6 pin plug of the wiper motor. The spot with the cross in it represents no wire.
The power wire from the switch needs to connect to the pin below the one with the cross in it. It's marked as LG in the diagram.
The earth wire can be connected to either (depending on what speed you want the wiper motor to go) the LG/R or LG/B these two pins are in the same row as the one with the cross in it.
Then connect the earth wire to the negative battery post.
Cheers Rodney
