How to wire a GQ Patrol Windscreen wiper motor for my Gold Drywasher
I'm guessing you don't need to worry about the wiper motor self parking??
Connect the fuse holder with the 20amp fuse to the positive post of the battery. Run wire from fuse to switch then to wiper motor.
In the attached photo you will see the 6 pin plug of the wiper motor. The spot with the cross in it represents no wire.
The power wire from the switch needs to connect to the pin below the one with the cross in it. It's marked as LG in the diagram.
The earth wire can be connected to either (depending on what speed you want the wiper motor to go) the LG/R or LG/B these two pins are in the same row as the one with the cross in it.
Then connect the earth wire to the negative battery post.
Cheers Rodney
Thanks for that Rodney it is greatly appreciated.
You are correct I don't need to worry about the self park.
I will give that a go I checked the pinout on the plug and its seems to match heres the plug and the wires going into it.
Wire colours are Black, Blue, Red, Red, Yellow and White
Hey mate, in regards to the self park function. Is it possible to get the wiper motor to run in high and low speeds, including self park when switched off if you are only using carling style switches?
