Results 11 to 20 of 24
Thread: RHS HID light not working
    581 Post(s)
    Quote Originally Posted by megatexture View Post
    Yep loose crimp on the relay or dodgy earth
    That's a better outcome then knackered ballasts.
    Thanks for your help gents!!!
    Too dark and I'm getting molested by Mosquitos so ill check it out tomorrow.
    Good outcome, thanks blokes!
    That would explain the intermittency then.
    Oct 2011
    Essendon
    I've been pretty tempted to pull my HID's out and upgrade the loom for more powerful H4's instead.....less "fussy" setup
    Sent from my iPhone using Forum Runner
  4. The Following User Says Thank You to Drewboyaus For This Useful Post:
    AB (11th October 2014)
  5. #13
    581 Post(s)
    Quote Originally Posted by Drewboyaus View Post
    I agree, I didn't realise how much crap was behind the lights, bowl of spaghetti!!!!
  6. #14
    brisbane
    Certainly cheaper fix that's for sure?
    Well no doubt your out there in only your jocks inviting the mozzies!
  7. #15
    581 Post(s)
    I am actually how did you know?
    Barmy Melbourne weather so the giraffe legs are back in the elements!!!
  8. #16
    brisbane
    Look behind you! Muwahaha
  9. #17
    581 Post(s)
    I'm sitting against a brick wall, I've seen your head, you ain't that skinny bro...lol
  10. The Following User Says Thank You to AB For This Useful Post:
    megatexture (11th October 2014)
  11. #18
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    I did that mate and it works.
    I then switched ballasts but no joy.
    So the problem being earth or power from controller down to connector into ballast?
    Has to be one of those two problems now?
    As said, just the wiring earths etc. each side should be seperately earthed. Hopefully it's something simple like a dirty ground. Bust out that rivnut gun and wack in some good earths
  12. The Following User Says Thank You to lhurley For This Useful Post:
  13. #19
    581 Post(s)
    Quote Originally Posted by lhurley View Post
    Thanks mate, glad it's an easy fix!!!
  14. #20
    Oct 2010
    Perfect earth is to the battery gu patrols have terrible earth points on the body and chassis
    Also could be the hid controller they don't like heat so that could be cactus
