10th October 2014, 10:21 PM
#11
Legendary
Still planning to head out for a drive, probably around lunch time Saturday if anyone is keen. Will be heading off from Yarra Glen to Toolangi via Pauls Range.
10th October 2014 10:21 PM
10th October 2014, 10:49 PM
#12
Moderator
Hey Rossco, are you going AirLockers mate? Nice one. Is your compressor mounted in the car or under the bonnet? If they are fitting it under the passenger seat make sure they fit vent tubes on each of the Solenoids or you will have the foul smell of hot diff oil in your cab. Sux. Easy and ahold come standard if they are cab mounted.
I am not aware of a run-in time needed for AirLockers? I certainly went out and played as soon as they were fitted.
Check out my Toy -->
Rogue Dung Beetle
10th October 2014, 11:42 PM
#13
Legendary
Yeah compressor is under bonnet. Air Lockers are in as well as 4.6 ratios. So far they are great, the car is more drivable, I have low range back and the speedo is pretty close to what it should be.
Speaking to the guys at the shop the main thing with running in diffs is to vary the speed so bearings and teeth don't wear in one pattern. Lockers are good to go tho.
10th October 2014, 11:54 PM
#14
Moderator
Nice one mate, you will love the 4.6s. Are they new or second hand? If you found some second hand ones they should not need bedding in.
Rogue Dung Beetle
11th October 2014, 12:10 AM
#15
MudRunnerTD
I have my compressor under the passengers seat and I haven't had the hot oil smell at all. The compressor won't run long enough for the oil to get hot enough, IMHO. But anyways. no smell from my compressor.
11th October 2014, 08:23 AM
#16
I think only the ARB locker vents back into the cabin.
I have ARB and PRO-locker good to go from the start.
I too would drop oil if bedding in new gears,
You'll love the locker completely new style of driving, enjoy
The Following User Says Thank You to threedogs For This Useful Post:
Rossco (11th October 2014)
11th October 2014, 08:41 AM
#17
Legendary
mudski
Mark,
The smell isnt compressor oil smell, it is hot diff oil smell, which can be quite fun
The Following User Says Thank You to happygu For This Useful Post:
MudRunnerTD (11th October 2014)
11th October 2014, 08:42 AM
#18
Legendary
Cheers guys the gears are new, I went a bit crazy with the $$$$$$ !!
Yeah looking forward to getting the feel for the lockers sould be bloody good!!
The Following User Says Thank You to Rossco For This Useful Post:
11th October 2014, 09:47 AM
#19
Hardcore
Rossco
Still planning to head out today mate?
Lucus30's 1999 GU ST TB45E
11th October 2014, 09:54 AM
#20
Legendary
Yeah mate. 12.30 at Yarra Glen for head off.
