Results 1 to 9 of 9
Thread: Vehicle communications
    Aug 2014
    Joondalup area
    Am about to travel and would love some information in regards to CB radio's and aerials. I need it for communicating with trucks and surrounding vehicles. Not much more. I will be the old fart (middle aged) that everyone rips past. But I want to be able to speak to the truckies for safety on the roads, overtaking and alike.
    Regards
    Phil
    Oct 2010
    Old Bar, NSW
    Mate if you can get hold of a 40 channel UHF.
    The new 80 channel units sound quiet on a receiving 40, which is a real PITA.
    The 40's will be good for years to come as long as you don't need channel 41 - 80.
    I have an 80, it was so bad I got the 40 repaired and put it back in. Much better.
    Macca
    Expert tikashooter's Avatar
    Dec 2013
    I've had no issues with my car mounted Uniden 80 channel unit. I also carry a 40 channel 5 watt hand held with mic attached which I've had no issues with receiving 'volume' from a 80 channel unit.
    Depends on whom I'm travelling with - ones set for the convoy the other ones set on 40 to speak with truckies or whom ever ( I'm lazy cannot be bothered changing channels )
    I hope this helps, after all it comes down to personal preference, budget and its intended use.
    Cheers, I hope all goes well with your trip.
    Respect the Bush
    Quote Originally Posted by havenfun2014 View Post
    Regards
    Phil
    For your useage I recommend that you forgo a vehicle set and all the hassles and purchase a handheld UHF CB of at least three Watts power (not a dinky little $50 1 watter)
    No need to wire up antennas, run power, mount transcievers and most will take an extension speaker/handset if needed
    For example here is a 3 watt GME with oodles of range for what you want, optional handpiece and under $210 http://www.prestigecom.net.au/GME-TX...ker-Microphone.
    Over the air noone will be able to tell the difference between that and a 5 watt vehicle mounted set.
    No brainer I reckon
    Apr 2014
    The other option if you dont want a permanent mount is one of the portable gme tx3100's
    http://www.ebay.com.au/itm/GME-TX310...-/400409369669
    In convoy situation a decent 5 watt hand held may suit your needs , not sure on legalities on using a hand held UHF.
    I know you can use an in dash unit in Vic, maybe some one know the rulings.
    If you want a base camp set up again a decent 5watt in dash unit with a good antenna, might suit your needs.
    Or you could just Velcro a unit to the out side of the centre console ,
    use a magnetic antenna base and plug it into your cigarette lighter for power.
    No drilling
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    I have my icom-400pro velcroed to my dash under the dash mat, just a temporary install until I get around to either making a roof console or sorting out another location. Works well there, I actually drilled a hole through the dash behind the removable panel above the glove box (second glovebox area) for the cables.
  9. The Following User Says Thank You to sooty_10 For This Useful Post:
    threedogs (2nd October 2014)
  10. #8
    .......... TPC's Avatar
    63 Post(s)
    Handheld radio's are not allowed to be used while driving in SA, same as mobile phones but they allow the use of fixed units.
    I would think it would be the same in Vic.
  11. #9
    My unit is hidden under the dash with the mic on the centre console drivers side ,
    but will be changing that so the passenger has something to do whether 4x4ing or convoy driving
