Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: New solar set up
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Overview of Setup 140W Solar Panel
    Battery & Redarc Solar Regulator SRP0120 20 Amp
    Fridge 60Litre Fridge Freezer with Remote Monitor
    The Battery is a 110AH Deep Cycle Calcium
    The Redarc Regulator will charge two Batteries and you can set the Ratios ie Fridge Battery 80% and Caravan Battery 20%
    and can be set for Calcium Batteries which require a higher Charge than normal Batteries
    The Cables between the Panel and Regulator were obtained from Jaycar
    I started the Fridge about half an Hour ago (Set to -19 degrees) and the Solar Panel is keeping the Battery fully charged whilst the Fridge Compressor is running continiously and has brought the Temperature down to -15 degrees
  2. The Following User Says Thank You to Bob For This Useful Post:
    threedogs (11th October 2014)
