Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: 2" lift the same on GQ & GU????
    Feb 2011
    Shed
    45 Post(s)
    I remember reading one of AB's posts that there is a difference in height of a 2" GU and GQ lift. A 2" GU is a 3" on a GQ is this right. I cant bloody find the original post/thread on this.
    22 Post(s)
    You could really heavy 2 inch gu springs in and it could lift it 3 inch, it is all a matter of spring rate.
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    growler2058 (29th September 2014)
  5. #3
    But remember the GU is a heavier car, so if you put GU springs in a GQ it will be a harsher ride.
    I have 2" GU springs in my GQ and it does not flex well but drives brilliantly on road. Would not have wanted anything else on the Simmo trip
  6. The Following User Says Thank You to Winnie For This Useful Post:
  7. #4
    581 Post(s)
    You have a fancy gu now so why the question?
  8. #5
    Feb 2011
    Shed
    45 Post(s)
    Because some companies say suit GQ and GU so if there is a difference I don't wanna get a 2" kit and its only bloody 1" if you know what imean
  9. #6
    CERTIFIABLY INSANE Drewboyaus's Avatar
    Oct 2011
    Essendon
    But remember the GU is a heavier car, so if you put GU springs in a GQ it will be a harsher ride. I have 2" GU springs in my GQ and it does not flex well but drives brilliantly on road. Would not have wanted anything else on the Simmo trip
    Mine flexes ok but I have quite a lot of weight on board. Winnie, once you get the rear bar and including your drawers you'll find it'll start to perform better.
    Growler, I have a very similar setup to Winnie but I have the Kaymar on the back and a steel drawer system with a heap of stuff permanently in there and my 2 inch GU lift sits at about 2.5 inches on the GQ
    1997 GQ Patrol RX, TB42E. Mods: OME 2" lift, 33" BFG KM2'S, ARB winch bar & reconditioned X9 Superwinch, IPF 900 spotties HID conversion, ARB side steps and scrub bars, Kaymar rear step & spare wheel carrier & jerry holder, Rear 55W LED worklight, Safari Snorkel, 147L LRA tank, Extended diff breathers, dual batteries, GME UHF, Home built drawer and fridge slide, ARB 60L fridge.
  10. The Following User Says Thank You to Drewboyaus For This Useful Post:
    growler2058 (30th September 2014)
  11. #7
    I only took the front sway bar out after the simmo too, always had it in before that.
  12. #8
    192 Post(s)
    I think Drew means your Raslar bar . . . You'll save some weight with the quarter chop tho!!
  13. #9
    I know what he meant I'm just saying it should make a big difference.
  14. #10
    192 Post(s)
    Fair enough!! Yeah reckon it wouldn't make too much difference, there wouldn't be to much between them.
