Results 1 to 10 of 13
Thread: Gu clutch noise
    Sep 2014
    Scone NSW
    Gu clutch noise
    Hey guys can't find anything in this thread but I have a noise which I can only describe as a helicopter noise type rattle and once clutch is pressed in goes away only notice yesterday morning while it was warming up and didn't notice it once it was warm. Don't remember this problem when I was at Nissan anyone else seen this before. Clutch feels good no other problems though.
    Cheers toad
    462 Post(s)
    The clutch release bearing carrier is rattling on the nose cone. When they are greased up you won't here it. Once the grease dries out it rattles again. Or, it's the bearing on that carrier. Could be either one.
    toad_au (29th September 2014)
    Sep 2014
    Scone NSW
    Cheers mudski well ill see how she goes those boxes are a pain to remove so won't remove it just to grease and quiet a rattle
    462 Post(s)
    Yeah when I replaced the clutch in mine I greased the carrier up and was all quiet. Around two month later it went noisy again and haven't worried about it since...
  8. #5
    Sep 2014
    Ayr
    As long as it's not the spigot bearing squealing away.
  9. #6
    Sep 2014
    Scone NSW
    Quote Originally Posted by JonnoDe View Post
    Don't believe it is as it's when the clutch isn't pressed in. Spigot works when clutch is being pushed it
  10. #7
    Legendary Alitis007's Avatar
    15 Post(s)
    Does the noise disappear when you press the clutch half way or all the way down?? It could be either the thrust bearing, gearbox front bearing or one of the cluster bearings inside the gearbox. I've heard 1 TB42 gearbox with noisy cluster bearings so far.
  11. #8
    Expert 90mav's Avatar
    Dec 2012
    Gold Coast
    Surely you could lube the carrier through the clutch fork hole with the boot removed? Maybe with some of that sticky chain lube in a can through one of those tubes that comes on a wd40 can? Just don't get it on the clutch... Got to be easier shot than pulling out the box, that's a painfull job!
    GQ Wagon 4.2 carb 4inch lift of the road resting
    GU Rd28 Wagon 2 inch lift on the road now daily driver
    D22 Navara ZD30- in rehab pending being moved on.
  12. #9
    Sep 2014
    Scone NSW
    As soon as foot presses tge petal it goes and if I put revs up slightly it goes and one warm it goes away hasn't changed since I've had it
  13. #10
    Sep 2014
    Scone NSW
    90mav I haven't tried
