6th May 2015, 12:18 PM
#11
Mine does the same its only the thrust bearing or carrier as mentioned I had a vl turbo that did it and I left it and that copped a lot of abuse I didn't worry until I changed the clutch and that was at least 2 years later
GU DX Cab Chassis TD42t non intercooled, 3 inch lift, genuine steel winch bar, 33" Pro Comp All Terrains , 3"turbo back exhaust, Icom IC 400pro UHF, 12inch LED light bar, 42" light bar
Future mods: Intercooler, more boost, dual batteries, drop links for sway bar
The Following User Says Thank You to luvpsi For This Useful Post:
6th May 2015 12:18 PM
6th May 2015, 12:26 PM
#12
6th May 2015, 12:38 PM
#13
Patrol Guru
Mine does it -was the same after I had a new clutch installed, was quieter initially but after a few months the helicopter is back. Kinda happy now I know what it is
Seemed like a good idea at the time
