Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Keyless entry remote on 2000 GUII absolute crap. Isolated or common issue?
    sick of fitting new batteries all the time , and now lock it with the key, easy peasy Bloody Nissan
    Aug 2011
    River Heads Q
    4 Post(s)
    Yep I just use the key as I don't have the option with the DX (and happy to do so)
  4. #13
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    Out of interest, has anyone read the GU manual? It says that the remote won't work from more than a meter away.
  5. #14
    Jul 2014
    3 Hrs West of Brisbane
    I can tell you my gu will only (sometimes) work from 1m. Looking into other after market options, thought I'd go whole hog, auto up windows and remote start as well.
  6. #15
    465 Post(s)
    Quote Originally Posted by mjr350 View Post
    I bought a kit from autobarn as jb didn't have them in stock. Pretty much the same as the warlock but it wort work. Ive got the indicators flashing and a 12v supply to the thick blue and blue/red but no door locking? Mudski, did you leave the old box in or remove it and I read somewhere that there's a relay under the drivers side that affects a few installs.
    EDIT
    Worked it out, there was a blue wire that needed to be grounded.
    The kit is a Cyclops TX90 and has all the bells and whistles.
    It can lock the doors as soon as the ignition is turned on if the doors are closed which I turned on because the missus is paranoid that someone is going to hijack us at traffic lights.
    It also relocks after 1 min 45 sec if no doors are opened and also has a feature that will close all windows as well if hooked to power window circuit.
    Does the warlock KG 400 have these options?
    The Warlock kit doesn't have those options. Good to see you got it working.
  7. #16
    Sep 2014
    Port Macquarie
    Quote Originally Posted by MuddyTroll View Post
    Go for the cyclone kit if you want the windows up option. $99 from autobarn and I can give you the complete wiring as the instructions are also made for smart people.
  8. #17
    Jul 2014
    That would be good, got a link or model number for me?
  9. #18
    Sep 2014
    Port Macquarie
    Cyclops KE-CLR-TX90
    http://www.mycyclops.com.au/products_locking_tx90.html\
    For some reason it says that it comes with actuators etc but mine didn't, its just the unit and remotes.
  10. #19
    Oct 2014
    Coolum Beach, Qld
    Hi. Mate, from what I've learned, I have to press my remote up to 20 times to get it working sometimes. Easier, just use key! Some say it's an earth issue. The body of the ZD30 wagon isn't earthed that well to chassis compared to the Ute. I tried adding another earth strap. Only have to press about 10 times now.Lol.
  11. #20
    Sep 2014
    Port Macquarie
    Quote Originally Posted by TJCPATROL View Post
    Read the manual. It actually says that the remote control won't work over a meter away. Nissan actually wrote that.
