26th September 2014, 04:56 PM
TD42 Need help please
Hi. I bought a second hand nissan patrol (single cab) last year. Y61, TD42. After replacing the clutch plate, pressure plate etc etc last week, no idea what went wrong. How do I remove the main crank shaft pulley to get to the timing cover. Hope I'm making sense Please help. Am a 33 year old female. I need my truck back on the road please.
26th September 2014 04:56 PM
26th September 2014, 06:20 PM
What are the symptoms ..... no drive, not starting, no power?
The Following User Says Thank You to happygu For This Useful Post:
Jorjina Paul (26th September 2014)
26th September 2014, 10:43 PM
There is power. The truck starts. Had a hard time bleeding the clutch. Tried to reverse out from under the shed and all of a sudden there was a loud noise in the engine. Took the gear box off again and finding it hard to remove the crank shaft pulley. Am lost and don't know what went wrong and where to start.
26th September 2014, 10:46 PM
Location?
Do you mean the flywheel is hard to remove?
What clutch did you use?
Did the noise stop the engine? Was it a rotational noise?
26th September 2014, 10:47 PM
Did you bench bleed the clutch cylinder?
1999 GU 4500 dual fuel
Il dado è tratto
The Following User Says Thank You to NP99 For This Useful Post:
26th September 2014, 11:14 PM
After the clutch, pressure plate and release bearing were replaced. Fuel line also flushed out. got the engine started, all was ok until I revved a bit too much causing a knock inside the engine. Dumb thing to do. Yes, it sounded like a rotational noise.
Jorjina
Papua New Guinea
