26th September 2014, 12:36 AM
What's the best way to get front flex ?
I'm resurrecting my GQ shortie project list at last
I'm rebuilding and laminating a Y61 front axle for the rebuild. While I'm at it what's the best way to go about getting max front axle flex ? ( I'm very poor by the way, so no off the shelf superior spending here ).
I'm thinking of booting out the panhard and going 4 link ? Is this viable ? I can weld and fabricate most stuff and good with a tape measure
At the moment I'm running 35" simex and have +2" susp and +2" body lift. The truck is used off road lots and only really drives on the road to get to the gig
I aim to do longer trailing arms at the back and bin panhard there too ( eventually lol)
Y60 Patrol 4.2 d SWB in puke green
2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
26th September 2014 12:36 AM
26th September 2014, 02:28 AM
Moderator
Fit a rear Sway bar will give you a heap of front flex becasue the back is restricted the front will move. works for me. a Treat.
Check out my Toy -->
Rogue Dung Beetle
26th September 2014, 03:08 AM
Legendary
1999 GU 4500 dual fuel
Il dado è tratto
The Following 4 Users Say Thank You to NP99 For This Useful Post:
93patrol (30th September 2014), Avo (26th September 2014), mudnut (27th September 2014), rusty_nail (30th September 2014)
26th September 2014, 03:24 AM
MudRunnerTD
Explain please in idiot speak I have no "sway" bars on mine at all. I thought they restricted flex ?
26th September 2014, 03:29 AM
26th September 2014, 03:32 AM
Moderator
Pretty simple really. The back of a Patrol flexes like a demon anyway. It flexes so well in fact that it will go to full flex without the front moving at all which is very frustrating. By fitting a rear sway bar the back has some restriction and the front is forces to move around a little an you get a heap of flex out of the front.
You will get better manners on road and far more flex off road with a rear sway bar fitted and no front sway bar.
This is my GUIV with a rear sway bar, no front sway bar and Drop boxes. Very happy with this setup.
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
04OFF (26th September 2014), growler2058 (27th September 2014)
26th September 2014, 03:39 AM
Darn it, I binned the old arb stuff ages ago too
Hmm !
26th September 2014, 10:38 PM
Want front end flex bin the standard patrol front end and go a 3 or 5 link.
27th September 2014, 12:28 AM
nissannewby
Yes agree Just been reading about them . My brain says to read it again ! I'm thinking more like 3 link at the mo but will read again again
27th September 2014, 07:20 AM
Like the guys have said, swaybar on the back will enable you to have more even flex front and back. Drop boxes are great because the correct the castor and radius arm geometry with suspension lift. Three link and a panhard is possible too, I have that in my GQ, check out my build thread there is a bit of info there.
A triangulated 4 link without a panhard is a totally different beast, very difficult to make it work in a patrol (engine and driveshaft in the way) you would need to go to hydrosteer because of the bump steer you would get with the current draglink and steering box setup.
GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
