Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Drivers side Barn Door a little low
    Jan 2013
    Quote Originally Posted by Parksy View Post
    I'm not 100% sure how they come off either, but you can buy replacement hinges so it's possible somehow. My guess is it's mounted internally and requires the door trims to come off to access the bolts.
    You can unbolt it inside the door next to the speaker hole. I replaced the hinge from the original door and that seems to have lifted it a little higher. Thanks
  2. The Following User Says Thank You to angelo_f For This Useful Post:
    Parksy (5th October 2014)
    Sep 2014
    Quote Originally Posted by angelo_f View Post
    Backed into a tree and the spare tyre buckled the door
    This may be the reason why it dont fit anymore check and see if there is anything else bent.
  5. #13
    Jan 2013
    Quote Originally Posted by Natolpatrol View Post
    The hinge off the replacement door was what was out. After changing it, the door aligns fine now
  6. The Following User Says Thank You to angelo_f For This Useful Post:
    BigRAWesty (5th October 2014)
  7. #14
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Sweet, easy fix.
