25th September 2014, 10:50 AM
24v or 12v starter for GQ 4.2 Diesel
Hi,
I need a starter motor for my GQ 4.2 Diesel.
When i search, i find both 24v & 12v to suit, which is the correct part?
25th September 2014 10:50 AM
25th September 2014, 11:06 AM
Zebinc
Hi,
Depends is your gq 24v some of the imports are. Local trucks tend to be 12v but you need to check what you have
25th September 2014, 11:39 AM
liftlid
yes more than likely it will be 12v or 24v if its a shorty import or lwb import.
25th September 2014, 11:50 AM
Travelling Podologist
Several simple ways to check.
Look at your starter battery(ies).
If your starter is a single battery you need 12v
If your starter is two batteries joined together (most likely side by side) you need 24v
(Do not confuse with an auxillary battery setup which will have a solenoid or similar between the two batteries & most likely not side by side)
Alternatively remove a headlight globe to see if it’s marked as 12v or 24v.
If you have a multimeter you could check the voltage across the two battery terminals (+ve on one, -ve on the other) to see if you get 12v or 24v.
The Following 2 Users Say Thank You to Cuppa For This Useful Post:
Stropp (25th September 2014), Zebinc (25th September 2014)
25th September 2014, 04:29 PM
So if i only have 1 battery it will be 12v, correct?
25th September 2014, 04:34 PM
The 747
Zebinc
Yes.
Regardless of that, 99% you will be 12V, 24V is rare but they are around.
25th September 2014, 07:22 PM
As Winnie says - Yes - Correct.
You don’t get 24v batteries, they are always made up of two or more lower voltage, most commonly 2 x 12v.
26th September 2014, 06:52 AM
Actually..you can get 24v batteries, my old unimog had a single 24v battery. I was looking I to running one in my Safari to free up the second batt tray for an aux battery...but they are not exactly easy to find here in aus unless you want to use a lithium marine battery
Cuppa
