1st May 2015, 02:28 PM
#11
Original came with 265 I'm running 275s currently with no lift
The Following User Says Thank You to toad_au For This Useful Post:
1st May 2015 02:28 PM
1st May 2015, 04:19 PM
#12
you're getting good miles from your Patrol thats for sure
1st May 2015, 04:35 PM
#13
Hardcore
toad_au
:-) pic of a crossing
Nice PIC looks like a good little crossing
Lucus30's 1999 GU ST TB45E
1st May 2015, 04:51 PM
#14
Yeah its going well I had to replace the injectors due to 2 leaky ones but it's going well had my first sliced tire last month was a fresh grated road will definitely lower pressures now was a costly exercise
1st May 2015, 05:02 PM
#15
Even if you only lower to 30 psi it helps,
at least you can drive on hwy if you forget your compressor
1st May 2015, 08:13 PM
#16
Thanks for the tip I'll remember that!
