Results 1 to 10 of 15
Thread: Sold engine mounts
    Beginner porkroll's Avatar
    Jul 2014
    Frankston VIC
    Sold engine mounts
    Hey patrolers, I'm about to do my engine mounts on my zd30di, and was just wondering if anyone has fitted solid mounts? I know solid can cause more vibration in car, I found these which have a damping, but would like to know if anyone has, & do you think they'll cause more engine vibration though the car? Or am I about to be a ginni pig! ! Cheers guys
    http://pages.ebay.com/link/?nav=item...656305&alt=web
    43 Post(s)
    I think Winnie has bought more solid mounts for his gq. Not quite like that but superior engineering do a more steel less rubber setup.
    I wonder if he's installed them yet??
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    porkroll (25th September 2014)
    465 Post(s)
    Zd30 mounts rarely break. Plus the oem mounts will obviously be smooth on the vibration. And those mounts are around the same as oem.
    I wouldn't bother if it were me...
  7. #4
    Yes I have and they are a lot noisier than standard at idle.
  8. The Following User Says Thank You to Winnie For This Useful Post:
  9. #5
    I would not be putting solid engine mounts on any vehicle
  10. #6
    Jul 2014
    Frankston VIC
    Morning all thanks for the replys, mounts aren't broken, but have a lot of movement stopping/taking off, just looking at long term, if benefits out way negatives. Cheers
  11. #7
    I would stick with OE mounts as you may be creating other problems with solids .
    Plus you may not like the out come so monies wasted
  12. #8
    43 Post(s)
    Thanks. So I'll go original then to ;-)
    Jul 2014
    Frankston VIC
    But only at idle?
  14. #10
    Jul 2014
    Frankston VIC
    Yes money Is the big issue!
