Results 11 to 20 of 21
Thread: Spare Tyre Cages
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Anything can be built mate. It's simply a matter of how deep are your pockets??
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    threedogs (25th September 2014)
    This is a great idea , saves lifting 45plus kg of tyre in the event of a flat.
    Its been around for ages and well deserves a bit of thought.
    Can you lift a tyre/rim combo over your head standing in sand.
  5. #13
    Ballarat, Vic
    174 Post(s)
    Quote Originally Posted by relyimah View Post
    you talking about these mate? have no info but may help others...
    http://steelstuff.files.wordpress.co...er-2-copy2.jpg
    They do look good, but heavy as others have said. I’d wonder if a much narrower & lighter ‘ramp’ would suffice just to enable rolling the spare up. As far as security goes, my spares have a similar centre screw mounting & security is a pretty simple but effective affair. The screw has a hole drilled through it & once the spare is mounted an R clip is pushed through the screw inside the vehicle, which can be locked.
    My ‘swing down’ spare mounts do still take a bit of effort to get the wheel up, but is far more easier than lifting up without (which I’m not sure I could manage).
    A Nomadic Life (Blog)
  6. The Following User Says Thank You to Cuppa For This Useful Post:
  7. #14
    There was a retired lady who had a GU ute to do the big lap years ago, someone fashioned up
    a similar system for her. Needless to say it worked a treat.
    @ Cuppa I can't see why you could not make it using 20x20x2 RHS, the struts are the easy part.
    in your case the both of you need to use equipment just incase an hope it never happens you get injured
    or have a medical episode out whoop whoop.
    I can visual a system similar to a drop down fridge bracket, being two stage
  8. #15
    Dec 2014
    Tambellup, WA
    Just stumbled onto this thread. I have built a set of these ( uncaged but still lockable) for my GU. Works terrifically and is built into the tray. I'll try and find some better photos.
  9. The Following User Says Thank You to LittleLeo For This Useful Post:
    gubigfish (20th December 2014)
  10. #16
    Aug 2014
    Perth
    10 Post(s)
    cheers mate be good to see some photos
  11. #17
    W.A. (wandering aust)
    Almost all of the tray manuf over here have them as options and Mike at XLR8 or other fabricators will make them custom if req'd.
    They usually fit them against the Cab so that you still get both sides and rear access to the Tray or Pod.
    Very popular on mine spec stuff because it reduces the manual handling risks associated with the spares
  12. #18
    Dec 2014
    Tambellup, WA
  13. The Following 2 Users Say Thank You to LittleLeo For This Useful Post:
    gubigfish (2nd January 2015), poindexter (19th February 2015)
  14. #19
    Mar 2015
    Sunshine Coast QLD
    Would ally be strong enought to support the weight of 2 tyres? i got a mate who does ally work so i could prob get him to make me somthing like tha, looks pretty trick.
  15. #20
    Dec 2014
    Tambellup, WA
    I'm not sure if Ally would be strong enough. I've built mine out of Gal. It wasn't too bad to build, mostly just trial and error to make the angles right ( I've built mine to hold up to 33's).
