Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: noob to 4x4ing and need some advice
    Oct 2014
    mickey atz are a winner
    Sep 2014
    Scone NSW
    Thanks guys
  4. #13
    Advanced jonez911's Avatar
    Oct 2014
    bfg kms
  5. #14
    Dec 2014
    Tambellup, WA
    G'day mate and welcome. Don't worry about the size too much. I would change all 5 to a 285/75r16 as a much more common tyre. They are a "33" and will do the job well.
    Yeh I agree. BFGoodrich or Goodyear's would be the way to go. Yokohama also do one called the Geolander. Whatever you get just remember to rotate at least every 10,000km. If you look after your tyres they'll last forever.
  6. #15
    Sep 2014
    Scone NSW
    Thanks guys ok need another tip on tyre pressures have been out a couple of times now but last time I lost a tyre leaving bush on a fresh crated road found flat at a gate looks like it was slashed by a rock side wall looked very wavy when reinflated?? so replaced it but to avoid this happening again what sort of pressure should I run on once I leave the main sealed roads? I was running road pressure as experienced mate never had a flat before but don't wanna be stung with killing another new tyre
  7. #16
    Patrol Guru SonOf's Avatar
    Dover, Tasmania
    I run the standard road pressure noted on the tyre. I lost 2 tyres to slashed sidewalls when I used to run Bridgestone DD's, one 2 weeks old but have not had any issues since switching over to Coopers. The majority of the good brands have a modle with added sidewall intrusion protection these days which is a great help in stopping what occured with your tyre.
    I run AT's but have a look at the type threads on here as guys are now sayign the current lot of MT styles are just as good onthe tar as the mud.
    Seemed like a good idea at the time
  8. The Following User Says Thank You to SonOf For This Useful Post:
    toad_au (6th May 2015)
  9. #17
    Sep 2014
    Scone NSW
    It wasnt the side wall that got cut but the actual tread was sliced
  10. #18
    40 psi if on the hwy, down to 20 psi off road lower on sand.
    Outback roads around 30 psi but drive to conditions
    Around town 35 PSI, thats general give or take to suit your needs
    Lowering pressures for off road help the tyre to mould to rocks for grip
    and prevent side wall damage , take care on the line you choose as well
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #19
    Sep 2014
    Scone NSW
    Thanks heaps that's exactly what I was chasing
