10th November 2010, 09:33 AM
Hi Darren,
You are right on the border of going 43 or 85 % reduction. The 85% gears will usually give you a top speed of 55kmph but with 35's and a petrol motor you should get a higher speed. The lower the reduction the better the car will hold up going down hills.
By far our most popular gears are the 43% they are a good compromise with low range ability and low range speed for sand etc. The reduction with the 43% with 35's will take it slightly below the standard ratio with 31's.
I hope this has given you a bit more information.
Hi Jason,
We only do a few old Ford V8 conversions to the Land Cruisers (60/70 series etc) nothing for the newer motors and nothing into the Patrols.
Cheers Elliot
10th November 2010 09:33 AM
30th November 2010, 02:27 PM
The vh45 just made 140rwkw with 35's.... Happy with that...
mmmm its a v8.... i'll have me one of those.....
30th November 2010, 09:13 PM
Marks 4wd
Hi Darren,
Cheers Elliot
Jeez, totally missed this reply for the last 20 days.
Thanks Elliot for the reply, that gives me something to think about.
Cheers,
Darren
21st January 2011, 10:14 AM
Hello Elliot.
You wouldn't believe how famous You are up here in Poland...
Your V8 conversions are now no.1 all mates are focused on.
More I am interested are Your very PORTALS to Y60 models with TD42T engines.
I've got friends in Sydney - no obstacles in purchasing I see. Anyway how You do about LHD GQ like mine?
regards from Poland
Rafael
24th January 2011, 02:09 AM
yes theyve got some pretty cool stuff if your into doin a conversion i was drewling over 1 of there kits for a long time but talked myself into a 25neo instead since i hav a gu 2.8
1st February 2011, 11:14 AM
starck
Hello Elliot.
regards from Poland
Rafael
Hey there Rafael,
We can do lhd portals no problem. We have just finished a set to go to Russia. So they can be done if you have an interest.
Cheers,
Sandy
26th May 2011, 09:43 PM
#17
Hey there , is there any kit from Marks to adapt a VK56 (V8 5.6 from the Nissan Titan / Armada) to a manual gearbox of a GU ??
Thanks a lot for your feedback !
25th June 2011, 04:37 PM
#18
Nissan Patrol 4.8 Petrol Conversion
I want to put a new 4.2 Diesel Turbo engine into my 4.8 Petrol Automatic Patrol. Is this possible and if so how do I go about sourcing all the relevant information?
Thanks wazza
25th June 2011, 05:04 PM
#19
SUCH IS LIFE
Wazza
Thanks wazza
Hey Wazza, I don't know if he gets on here that often mate. Might be quicker to give him a call on Monday....but you never know.
________________________
______ 2017 D-Max _______
27th June 2011, 10:54 AM
#20
Hi jpvm,
As yet we haven't looked at fitting the 5.6lt motor, if Nissan's other motors are to go by the bolt up patterns could be the same (4.2, 4.5, 4.8)
As soon as anything is looked into I will let know.
Hi Wazza,
We specialise in fitting V8's.
The bellhousing to block will bolt up, you will need to run an early TD42 Auto flexplate (out of a GQ), you will also need to re tap the TD42 starter motor bolt hose in the 4.8 bellhousing. There might be a couple of other things to do but not much. The engine mounts are in the same position.
You could give a good Nissan wrecker a call and see if they have any more information. To get the auto running you will need to feed it with the correct signals - talking to someone like Kewish Autos or Wholesale Autos should sort you out there.
If anyone has any more questions just post them up - i'll try to remember to check here as often as possible.
Elliot
