Results 1 to 3 of 3
Thread: Water in swivel hub
    Jan 2013
    Water in swivel hub
    Greetings
    I have a GQ patrol and I went through a deep water crossing. After removing one of the bolts when checking the swivel hub, water came out (only on one side). I have checked dif and there was no water entry there.
    What should my next step be?
    remove a FWH's both sides and see if any water has been sucked past the seals ,
    hot diffs and cold water not a good combo
  4. The Following User Says Thank You to threedogs For This Useful Post:
    angelo_f (16th September 2014)
    80 Post(s)
    Mudrunner's thread will help you heaps. I used a fine wet'n'dry on the axle housing so the seals don't get chewed out again.
    http://www.nissanpatrol.com.au/forum...highlight=hubs
