I also have OME in mine and as above, it's a bit stiff when not fully loaded but when out in the bush and under load it's faultless.
A few of the guys who did the Simpson Dessert a couple of months back were running OME and have commented they wouldn't run anything else after that trip.
I know a few people who haven't been all that happy with Ironman's foam cell shocks but they have a new model out just recently that I can't make any comment on.
Like I said earlier though, it really depends what you're planning to do with your vehicle but if it's a bit of an allrounder then from my experience I highly rate the Old Man Emu gear.
Sent from my iPhone using Forum Runner
thanks for the reply's everyone, i think for my peace of mind i will go OME i got quoted 2" springs and shocks $1570 installed +$350 for new bump stops and spring seats does this sound reasonable ?
2nd question how does self installed effect warranty? not been that mechanical at all but have a few brain cells floating about do yous think i should do it or get it done by the pros
thanks for all your help everyone
cheers brent
2.8LTD GU ST, Arb winch bar, tigerz11 dominator 12000lb winch, safari snorkel, black widow rear draws, roof console, 2 uhf's,
cheers brent
Why do you need new bump stops?? Are your flogged out? If they are then your car has seen some very hard days! I reckon they are having a lend of you! Same goes for the spring seats! If you rubber spring seat rings are in good Nic then leave them right where they are! If not then I have made my own using 5mm reinforced cross ply rubber from Clarke rubber for a 1/10 of the price of 1 from Nissan!!
Installing a 2" lift is very very basic stuff and there is. Few threads here on just how easy it is. Fitting yourself should not effect your warranty as long as you do it right. If you go OME as a matched Kit then your on a winner and your warranty will be strong. If you mix and match your springs and shocks then you are open to the manufacturer blaming the other guy for a poor ride quality! "It's your shocks mate!" "No it's your springs mate!" See what I mean.
Hope that helps.
thanks for the reply's everyone, i think for my peace of mind i will go OME i got quoted 2" springs and shocks $1570 installed +$350 for new bump stops and spring seats does this sound reasonable ? 2nd question how does self installed effect warranty? not been that mechanical at all but have a few brain cells floating about do yous think i should do it or get it done by the pros thanks for all your help everyone cheers brent
I'm curious as to why you need new bump stops.....
The job itself in swapping over the shocks and springs for a 2inch lift isn't that difficult, expect it to take a few hours. I'm pretty sure there is at least one guide on here as to what's required in the job.
ok this is my front bumpstop both look like there missing a bit off the bottom but seem some what good to me ? whats your thoughts ? 1.jpg
and this is the spring seat at the front seems to be a bit degraded and may need replacing ?untitled2.jpg
cheers for the help guys
brento
Sorry the pics are tiny even on the computer. can you post them again or add them to photobucket and they should be zoomable then. The spring seat looks like it has sen better days but they are expensive and i used Reinforced rubber as above for the win.
Your bump stops should have a formed rubber ring around the base and i cant see that pic at all sorry. If they looked damaged they may well be. What size is the lift that is in it? i assumed it was unlifted before?
