Results 1 to 9 of 9
Thread: Fairey type overdrive for patrol
    Patrol God Stropp's Avatar
    31 Post(s)
    I know you can get them for early 4 speed patrols but cant seem to find any info on later model 5 speed ones, can anyone help?? it would be an easy way to swap between 33 to 35's without doing the diffs.
    Last edited by NissanGQ4.2; 10th September 2014 at 05:48 PM. Reason: Fixed spelling in title
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    What ratio is your 5th gear now? Nissan updated all GU Patrols as of 08/2004 with a longer spline main shaft and 5th gear according to Marks 4wd
    Would this achieve what your after? http://www.marks4wd.com/mfk730.html
    31 Post(s)
    Yeh I have the 11/04 model but I was chasing the lower gearing the fairey type gives you as it gives you a half gear which would be great with the 35's
    Fairley were vacuum operated weren't they,
    from memory the early Patrol OD was a mechanical lever on the floor
    31 Post(s)
    another stick 3D, i was very interested in one back in the early 80's for my "other" 4wd.
    Stretching the memory but I'm sure it was just a lever to engage/dis-engage.
    Mates Rangie had the vacuum diff loc when we went to the Cape in '83
    some 60s had them too I think
    Patrol Freak gaddy's Avatar
    redlands
    One of my mate's had one on a series 3 landy , separate stick to give it 5th gear on the hwy
    31 Post(s)
    No this is a seperate stick to give you a split gearbox so a 1/2 gear between each gear nothing to do with the diff
  10. The Following User Says Thank You to Stropp For This Useful Post:
    threedogs (12th September 2014)
  11. #9
    Advanced johno1938's Avatar
    Sep 2014
    s.e. qld
    just put a 18 speed road ranger in with tall diffs
  12. The Following User Says Thank You to johno1938 For This Useful Post:
    Avo (26th October 2014)
