10th September 2014, 11:46 AM
Tough Dog RTC Damper
Hi all!
I'm in need of a new damper does anyone have one of these, what are your opinions of them?
06 TD 4.2 coil cab, 3 inch lift, front ARB air locker.
10th September 2014 11:46 AM
10th September 2014, 11:52 AM
Chit! I am on my second one, first was a warranty return. This one looks to be heading the same way as the first.
10th September 2014, 01:03 PM
Hardcore
From what I've read most people don't like RTC's and seems that they aren't very reliable. Any Reason you want a RTC?
Lucus30's 1999 GU ST TB45E
10th September 2014, 01:58 PM
This discussion has been done to death mate.............. just buy a proper one and not a RTC.
Have a little look on all the talk about these that has been discussed in the last couple of years.
10th September 2014, 02:06 PM
I just heard they improve your handling on the black top when running a 3inch or higher lift and 315's but I think I'll steer clear of them after hearing your guys opinions of them and get a normal one can you recommend me one in particular?
P.S. Sorry if I dragged up an old discussion I was just after some current information is all.
The Following User Says Thank You to LachDiggityDog For This Useful Post:
Bloodyaussie (10th September 2014)
10th September 2014, 02:16 PM
Kings do a nice one. I use to run a toughdog adjustable one and found that to do the job well with a 5" lift and 35's.
Steer clear of RTC
10th September 2014, 02:18 PM
LachDiggityDog
As mentioned in the other thread they only mask a problem you have.. and there are many stories of them failing also..
I have a good heavy duty Tough Dog that is adjustable for around the same money.
10th September 2014, 02:54 PM
Thanks for all the advice gents might go with a Tough Dog adjustable
10th September 2014, 03:23 PM
Dribble Master
I must have been the only one who quite liked using one the, particularly on road. I liked the fact that they stiffened up the feel of steering as I tended to find power assisted steering a little sloppy, especially at speed. In saying that, I did manage to bend mine due to hitting a rock a wee bit hard...... I've replaced it with a toughdog adjustable to try something different...... This I also like due to being able to stiffen up the steering to how I like it to feel
