Results 1 to 7 of 7
Thread: TD42 Knock
    Feb 2013
    TD42 Knock
    Hello. Just took my new motor for a drove and heard a knock. Oil pressure is fine. Its coming from the top end.
    I started cracking injectors of and found that when I crack no3 the knock goes away.
    Iv also noticed that there is no where near the amount of spray coming from that injector hose.
    If I crack it at the pump I get a decent stream
    Has anyone encountered this kinda problem.?, should I just try blow out the line ?
    Iv been told it could be a fault injector staying partially open or closed
    Feb 2011
    Shed
    45 Post(s)
    Bump........
    Swap the injector with another one and if the noise follows then it will be a crook injector.
  5. The Following User Says Thank You to nissannewby For This Useful Post:
    growler2058 (7th September 2014)
    Aug 2014
    Armadale, Perth
    This is the cheapest and easiest way to find where the fault is.
    If the knock follows that injector then get a new one (a set would be better). If the knock stays at #3 then it could be the line or pump. A line will be a far cheaper fix than the pump so I would start with that, not sure how the line would block though, maybe damaged while playing with something else?
    You said new motor, is this new car or new engine? The #3 cylinder could also be an issue. When/who set the tappets? This could contribute too.
    Bit hard to be accurate on a keyboard sorry
    Feb 2013
    Motor is brand new, iv had the motor running for 3 weeks and not had a knock until I took it for its first drive yesterday, I did clean the line out yesterday as it was a little blocked. the knock goes away when cold and if I crack the injector. iv been told to remove the injector and pull it apart as the pin might be sticking or getting caught. tappets were set before the motor went in, there is no noise from the tappets. has good oil pressure aswell.
    Injectors and pump were brand new when installed. im hoping its just a little bit of shit in the injector
    Aug 2014
    Armadale, Perth
    It kinda sounds more like injector from what your saying. I would try and swap into another position as described above to confirm.
    Feb 2013
    that's what im hoping, I did start it today and it made the noise when cold just above idle. rev it and it disappears. ill be pulling the injectors out tomorrow and pulling them apart to clean them
