Results 1 to 9 of 9
Thread: 1998 gu need help changing rear rotors ???
    Sep 2014
    Tannum
    Anyone got tips on how to or is it easy to change rear rotors and pads???? Thx workshop manual would be good?..
    Easy. Pull wheels off, remove calipers, rear rotors then just slide off (may need a little persuasion), change the pads and reassemble.
    Sep 2014
    Tannum
    Thanks mate I'll see how I go
    Expert GUte's Avatar
    Perth
    Cant remember for sure but if there's a threaded hole or two on the rotor, find a spare bolt and use this to pry the disc off if its tight
    Aug 2010
    adelaide
    there is a few other things you need to do
    eg take out 1/2 break fluid
    calipers need to be spread open so as to get the new pads in
    go to youtube and watch someone doing it
    and it gives you a better knowledge on how to do the job
    here is a link
    https://www.youtube.com/watch?v=gE59rKXEoos
    OH LEATHER IS NICE
    Sep 2014
    Tannum
    Just finished changing them was really easy and they are great
  8. The Following User Says Thank You to Bogan_dano For This Useful Post:
    MudRunnerTD (3rd September 2014)
    Sep 2014
    Tannum
    Had to change the fuel filter and finally found where it was that was easy to change as we'll
    I need to change the fan belts and all that will be next weekends job ... Then put my rooftop tent on and I'll be ready for some people to come 4wding with me
  10. #8
    Good to hear you finished OK, fronts are a bit trickier..
    Where's Tannum???
  11. #9
    Sep 2014
    Tannum
    Qld near Gladstone
