2nd September 2014, 09:25 PM
1998 gu need help changing rear rotors ???
Anyone got tips on how to or is it easy to change rear rotors and pads???? Thx workshop manual would be good?..
2nd September 2014 09:25 PM
2nd September 2014, 09:27 PM
Easy. Pull wheels off, remove calipers, rear rotors then just slide off (may need a little persuasion), change the pads and reassemble.
2nd September 2014, 09:31 PM
Thanks mate I'll see how I go
2nd September 2014, 11:29 PM
Cant remember for sure but if there's a threaded hole or two on the rotor, find a spare bolt and use this to pry the disc off if its tight
3rd September 2014, 08:37 AM
there is a few other things you need to do
eg take out 1/2 break fluid
calipers need to be spread open so as to get the new pads in
go to youtube and watch someone doing it
and it gives you a better knowledge on how to do the job
here is a link
https://www.youtube.com/watch?v=gE59rKXEoos
OH LEATHER IS NICE
3rd September 2014, 12:18 PM
Just finished changing them was really easy and they are great
The Following User Says Thank You to Bogan_dano For This Useful Post:
MudRunnerTD (3rd September 2014)
3rd September 2014, 12:21 PM
Had to change the fuel filter and finally found where it was that was easy to change as we'll
I need to change the fan belts and all that will be next weekends job ... Then put my rooftop tent on and I'll be ready for some people to come 4wding with me
3rd September 2014, 12:23 PM
Good to hear you finished OK, fronts are a bit trickier..
Where's Tannum???
3rd September 2014, 07:08 PM
