Results 1 to 5 of 5
Thread: Quick fix for loose side mirror
    Jul 2014
    Hi Guys,
    Found my drivers side side mirror vibrating a lot, it was so bad it was difficult to use safely.
    I had a look and the yellow part had broken away from the mounting frame in the side mirror housing.
    I just used 200mm black zippy ties to relocate it and it works a treat.
    Here are some photos.
    Neil.
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Interesting, Mine has some goo/bluetack not exactly sure what under the bottom edge of the mirror between the black housing. The previous owners had put it there, I went to remove it and seen the mirror became affected badly by vibration so didn't remove it. This might be what's wrong with mine, might have a look one day soon.
    Thomastown, Melbourne
    6 Post(s)
    Mine had silicon holding it in place so I pulled it apart and plastic welded it and now it is perfect..... only took me 2 years to do it though...LOL
    Bendigo
    7 Post(s)
    So I've got a bit of time up my sleeve left till I should be fixing it.
    581 Post(s)
    My drivers mirror keeps vibrating and eventually points down. Been like this for 2 years now...really need to do this myself.
    It's one of those jobs you forget until your driving!!!
