7th September 2014, 10:29 PM
Don't have a pic, I'll get one in the next few days.
7th September 2014 10:29 PM
8th September 2014, 08:08 AM
Dan.
So I had a good look at the idle adjust today and I can't get to it, compaired to the above pic I think I have a boost compensator over the idle adjust screw.
Glad I was of some help. Dang boost compensator, you should pull it off and send to me
8th September 2014, 10:19 AM
I had my old GQ behave the same way. Timing was out. Minute adjustment of the injector pump timing and all was good again.
Hopefully you'll have it sorted soon
14th September 2014, 08:44 AM
Hi guys, finally had a few seconds to take a pic, first how do i get to the idle screw? second whats that on top of my IP, why does it look different to Muddy's pic above?IMG_1258.JPGIMG_1259.JPG
14th September 2014, 09:17 AM
If you have a small 1/4" socket set you can get onto the bolt that adjusts the idle. You should be able to get a spanner onto the lock nut. Its a little fiddly but doable.
That is a boost compensator. The idle just is still there and accessible just a little more tricky.
23rd September 2014, 10:00 PM
Done, idles much smother now, but as mentioned above very fiddly. Thanks to all that commented.
23rd September 2021, 10:19 PM
#17
Dan.
Can you get a pic and show me the idle screw please, still can’t find it cheers
