Results 1 to 6 of 6
Thread: 2010 GU 7 Grill Removal
    Expert clubbyr8's Avatar
    Penrith, NSW
    I'm trying to take out my headlights to replace the indicator globes with leds. There's 3 bolts holding the light assembly in but it looks like the grill has to come out too. I've got the top clips out but for the life of me I can't remove the bottom clips. The manual doesn't really say much except remove clips. The bottom ones look like they turn but I can't seem to move them. Anyone got an easy solution or any solution for that matter...
    GROOVY GUVII
    175 Post(s)
    Mine just pop out outwards. So pull away from the engine, once you pop the top ones and grill should come out.
    Sent from my SM-G900I using Forum Runner
  4. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    clubbyr8 (28th August 2014), LaughingBeagles (8th April 2015)
    Penrith, NSW
    Thanks mate, that seems to be the way although my factory bullbar is stopping me getting it out, very little room to pull the grill forward....
    GROOVY GUVII
    Yes the bottom clips are a bugger. i had to lever them forward from underneath from memory. A second pair of hands for the win. It can be done alone though.Kind of a silly clip to have there.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    clubbyr8 (29th August 2014)
  8. #5
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    And once you've broken both of them, zip ties work quite well when you re-secure it all back in place...
  9. The Following 2 Users Say Thank You to FNQGU For This Useful Post:
    clubbyr8 (29th August 2014), LaughingBeagles (8th April 2015)
  10. #6
    Penrith, NSW
    There is no way I can lever the grill out of the bottom clips. The grill is about 3mm from the factory alloy bar. To me it seems the bar is tilted upwards, although it looks reasonable on the sides, or maybe it's the shape of the grill. Short of breaking this clips, any suggestions?
    GROOVY GUVII
