Results 1 to 8 of 8
Thread: No power to head light fuse
    Advanced elmo4eva's Avatar
    Dec 2013
    Hey ppl just wondering if anyone has occured this with no power going to the head light fueses can any one help me out with it plz
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    I just looked at the GQ wiring diagram, and it says that the terminal at the top of the fuse holder is "hot at all times" so there should be voltage present if the battery is connected. You might have to undo the fuse block and check that the wire is connected properly. If it is ok, then trace the wire back to the battery, making sure all connectors are pushed together tightly. Sorry, I can't find a diagram with the wire colour.
    Advanced scubasteve's Avatar
    Redland Bay, QLD, AUS
    Im currently dealing with my indicators doing the same thing. I have 12v leading into the fuse bix but not at the fuse. Whilst I havent had it confirmed yet I have a feeling the internals of the fuse block may have shit themselves and there is a break somewhere internally. Im in the process of getting it looked at while im away for work so I can update with what gets found in mine
    1989 Ford Maverick: TB42s Carby, Snorkel, 3" king spring suspension lift, 2" body lift, aftermarket extractors, 33x12.5 mickey t MTZ's, 2.5: Sports Exhaust
    Nov 2010
    Adelaide
    I think there should be a fusible link under the bonnet. My wiring diagram shows a white wire in from the battery and red wire out to the headlights.
  6. #5
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Start by checking the main fusible link for the headlights out near the battery. If this is not blown or corroded then remove the internal fuse box and check the large red wire has power that goes to the headlight fuses.
    Did you end up fitting relays to the headlights?
  7. The Following User Says Thank You to Yendor For This Useful Post:
    mudnut (31st August 2014)
  8. #6
    Dec 2013
    No I have no clue of connecting relays to the headlights I need help with that I need someone to show me the wiring diagram to do it
  9. #7
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I think the best way for you is to buy a plug and play harness.
    This won't fix your problem if you don't have power at the fuses.
  10. #8
    Dec 2013
    Found the problem the main wire at the battery for the headlights was fuked the plug was corroded and the wire was fuked
    Thanks for every ones help
