27th August 2014, 08:18 PM
CB radio interference from car stereo
Hi Folks
I have installed a GME Tx3100 80 channel CB radio, which works fantastic when the car stereo is turned off, but when I turn on the stereo the CB just crackles like crazy (like a squelch noise). I have taken the antenna cable out and re-routed it as I thought it might be passing too close to the back of the stereo, but its now way away from the car stereo and still has the interference. As soon as I turn off the stereo I have perfect CB again.
I have heard that I might need a 'suppressor' but would value your opinions on what to try next. I tow a caravan and also live on a logging trail so find the CB useful, but would also like to be able to listen the car stereo too.
A little more info is, I use a new 6dB uniden bull bar mounted antenna which came as part of a package.
The power source for the GME comes from a permanent live under the dash, and wondered if this might be the source of the interference, although I don't think this is linked to the car stereo.
What do you think is the most likely cause of the interference.
thanks all,
Mark
2012 GU8 ST CRD Platinum Silver with Tints, Factory Bar, IPFs, Snorkel, UHF, Maxtrax, Rated Recovery points front/rear, In dash Nav, Scangauge2, Ally Roof Rack, OME 2" Lift
27th August 2014 08:18 PM
27th August 2014, 09:53 PM
I would suggest taking the power from the battery, connect the positive direct to the battery with a fuse and the negative to a good clean earth point close to the battery.
28th August 2014, 09:42 PM
Try removing the antenna from the cb - if you are still getting the crackle - most likely power supply issue and a suppressor would help. Also run top the battery and move the earth - or run the earth to the chassis point near the battery.
If the noise has gone away - probably RFI interference from the radio
29th August 2014, 10:12 AM
thanks, trying a direct power source from battery today.
Yup, fixed,
