Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Battery Going Flat
    NT
    Another way is to disconnect all the small wires from the battery (with everything off).
    Touch them individually to the battery. Any sparks indicate current draw. Although not scientific, a rough guide is
    small orange sparks - small current draw
    Larger orange sparks - more
    Small blue sparks - more current
    Larger blue sparks/audible click lots.
    Now don't laugh at me, but it is a quick and easy way to work out which wires are worth a second look with a multimeter.
    Another option is to put in a solar panel. A small type that plugs into the cigarette lighter might do. Any larger panels would need a solar regulator.
    Another option is to refit the battery with another cranking battery. It will last twice as long then.
    (and of course these options are merely masking the problem).
  2. The Following User Says Thank You to P4trol For This Useful Post:
    harrythomas (27th August 2014)
    Germany and NZ
    If using the above method and yours is a petrol engined Patrol observe the usual precautions for welding on carburettors
  5. The Following User Says Thank You to K1W1 For This Useful Post:
    P4trol (25th August 2014)
  6. #13
    Advanced harrythomas's Avatar
    Oct 2013
    Proserpine Qld
    I have been through all the fuses K1W1 and only found a small current on the radio/cd circuit which I think is normal.
    I have no small wires left on the battery P4trol but thanks for the “rough guide” regarding the different sparks. Good for future reference. There was three small wires on the main battery when I purchased the vehicle but after this problem started I have tracked them back. They all went back into the cab then went nowhere so I have removed them. I think there has been some backyard wiring happening on this vehicle so I seems there is more to find yet.
  7. #14
    Oct 2013
    Proserpine Qld
    Battery Problem Solved
    Monday afternoon I discovered this
    behind the dash jammed between the all the wiring and the firewall. All the wires on it were cut off it except the power inlet which was hard wired into a circuit which remained live when the key was turned off.
    It is now in the rubbish bin and the battery has held it charge since then.
    Thanks for all your advice in trying to sort this out.
    Harry.
  8. #15
    Legendary happygu's Avatar
    Quote Originally Posted by harrythomas View Post
    Harry.
    Great work Harry, and good persistence too....
  9. #16
    Expert graeme1969's Avatar
    Jun 2013
    Wesley Vale, Tas
    What is it?
  10. #17
    Aug 2010
    adelaide
    on board phone kit for nokia phone
    OH LEATHER IS NICE
  11. The Following User Says Thank You to my third 256 For This Useful Post:
    graeme1969 (28th August 2014)
  12. #18
    Oct 2013
    Proserpine Qld
    Thanks mate, and a few more grey hairs.
