Results 1 to 6 of 6
Thread: Oriom
    Oriom
    to oricom or not to..looking at setting the gu up with a cb aswell this week before we head off..oricom are heaps cheaper..5 watt 80 channel with arial,complete package down here for $280,the gme equivalent is $430.
    So what I want to know are they alright?
    TIA neil
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    G'day Neil,
    I have the Oricom 5w UHF unit in mine from Supercheapauto and the 3db + 6db antenna package
    Total cost $266.95
    Easy to install and they work great.
    http://www.supercheapauto.com.au/onl...m=100601#Cross
    http://www.supercheapauto.com.au/onl...m=100602#Cross
    Cheers,
    Rob
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
  4. The Following User Says Thank You to rkinsey For This Useful Post:
    Avo (21st August 2014)
    Patrol Guru TimE's Avatar
    Canberra
    3 Post(s)
    There is better quality gear at good prices around if you have a look.
    Try Prestige Communications lots of good deals and with quality gear at pretty good prices.
    No affiliation just a happy customer.
  6. The Following User Says Thank You to TimE For This Useful Post:
  7. #4
    cheers guys,not enough time to get one ordered and down here then fitted,have spoke to a couple of people and I think the oricom will do me for now..in a bit of a rush as we're leaving next week so I had to get one now and get it fitted over the weekend.Small town I live in and had to grab what was available.the saving lent me towards the oricom,and yes prestige have a good name over here.only found out I can have 2 weeks off on Monday so rushing around to set the car up.leave on the 28th
  8. #5
    Apr 2011
    Melton
    I thnk the big question is? whats the after market support like.
    Can you buy replacment mics
    what is the warranty plan / and support
    As long as the specs are the same as every one else (and they should be to obtain the acma type approval) - they should work the same (range / channels etc)
  9. #6
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    I bought an Oricom UHF-180 / 80 channel to replace my old 40 channel Uniden 015SX.
    When I went to fit it the head unit to the mount, the thumb screws were too long and would not tighten as they were bottoming out in the head unit.
    I phoned Oricom about the issue. They said they would post me some shorter screws.
    I received them next day, sent by overnight postage.
    I have no complaints about the unit or the service.
    Was a CRD
