Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Temperature sensor problem (unsolvable)
  1. #21
    Patrol Freak kevin07's Avatar
    georges hall
    what im saying is that my o2 sensor was good on computer but when I took it out it was no good all the fins were closed.
    07 crd,,bridgestone 697lt, 2.75 buedesert ex, SOLD theres a lot of my blood, sweat and money in that troll.
    92 gq ti tb42efi my brothers gq extractors dual batteries brake controller uhf alloy bullbar SOLD with a heavy heart but gone to a nice young fella
    13 y62 the beast that burbles
    georges hall
    the water thing have you done a compression test.
  4. #23
    georges hall
    next step on the water loss if there is no evidence of it leaking is take for a dye test and or listen to the exhaust for a small hissing noise and or popping
  5. #24
    Beginner oldcrazyman's Avatar
    Aug 2011
    Ménéké (Grand Bereby), Cote d'Ivoire
    Quote Originally Posted by kevin07 View Post
    ok i'll check the o2 sensor.
    What about the water compression? Do you mean to press the big tube going from radiator to thermostat when engine hot?
    If you are talking of that, yes i did it. It's pretty hard, I can't totally press it, but I can press ah half of its diameter, more or less...is it correct?
    Gus, the oldcrazyman[COLOR="White"].............[/COLOR] GR Y60 4.2 EFI LWB auto, [B]The Pequod 2[/B]
  6. #25
    georges hall
    if its not taking water from the overflow it may not be pressurising properly is there any signs of a leak if not it has to be going through the exhaust. that's why I want you to listen at the back of the exhaust for any sort of hissing or popping.but the compression test is on the cylinders. you need a compression tester to do it from where the spark plugs are.
  7. #26
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Also check that the radiator cap is sealing at the lip. Water will expands with heat and when it cools it drags air in instead of water from the tank.
  8. The Following User Says Thank You to mudnut For This Useful Post:
    kevin07 (29th August 2014)
  9. #27
    Aug 2011
    Hi all,
    I just finished to check all you guys said, nothing came out. The car still has the same problems exposed in the first post.
    The engine start to show those problem only when it's getting hot, otherwise, when cold it's perfect!
    @ kevin: i just took out the O2 sensor...sorry but mine has not fins...check the pic
    I'm loosing the hope....
  10. #28
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Considering the O2 sensor has probable been in there since it was made it would be an ideal time 2 put a new one it anyway, regardless if it fixes the problem or not
  11. #29
    Aug 2011
    Ok thanks, I will buy one from the site posted by Kevin.
    Do you guys think it's better to buy even a new coolant temp sensor? We tried three of 'em, but all were old and extra used.
    Maybe with a new one the problem could be fixed.
    Today I tested much better my problem and I've seen that this temperature (photo) is the limit to a good performance. A lil bit hotter than that and the car does what I explained...
  12. #30
    Aug 2010
    17 Post(s)
    Those temp gauges mean nothing, mine normally if I remember correctly sits about half way or a bit more.
Tags for this Thread
