18th August 2014, 02:11 AM
2001 4.5ltr patrol help
hello guys and girls
i need help. (in more ways than one lol)
i need someone with a 4.5ltr to take a photo of where the engine coolant temp switch pluggs into please. i have tryed and tryed to find in manuals but with no luck, even had it to a mech and he said yep it should be conected but even he dosent know where.
so please help
18th August 2014 02:11 AM
18th August 2014, 03:10 AM
Legendary
Try a Google image search. If I remember I'll take a shot of mine, if I can find it... You after the switch or the sensor.
18th August 2014, 07:28 AM
The sensor where the plug plugs into. The sensor that is in the bottom drivers side of radiator please
18th August 2014, 09:29 AM
Patrol Freak
I'm not sure what you're calling an 'engine coolant temp switch'. My 2001 4.5 auto has no temp sensors in the radiator itself.
If you're referring to a wiring loom on the RH side with a grey 2 pin plug, it's for a 2nd electric fan in some markets. There's a place to plug the relay in just behind your battery.
Perhaps you could put up a pic of what you think should be connected?
John
18th August 2014, 05:14 PM
Hello here is a photo of what I mean. The one attached to fan housing is a sensor from under the radiator and I think it is ment to plug into the lose one but both male plugs
18th August 2014, 05:16 PM
19th August 2014, 05:39 PM
Patrol Freak
I have one of those plugs taped up behind the A/C receiver/dryer but not the one you have clipped onto the fan shroud.
I took pics and can post tomorrow if you want to see..
John
19th August 2014, 07:17 PM
20th August 2014, 07:58 AM
Patrol Freak
Here's a pic of the plug on mine that is taped to the loom behind the A/C drier.
I think it's pretty clear that it has never been in use.
Pic showing nothing clipped to the fan shroud.
As mentioned, I have no sensors in the radiator itself and it has never been replaced.
Mine is a 2001 TI so it's auto trans.
John
23rd August 2014, 07:18 PM
I think those plugs are for the AC system pressure switches?
The plugs for the coolant temp are both on the head near No1 cylinder - the two wire one is for the ECU, the single wire one is for the instrument panel gauge.
