17th August 2014, 08:31 PM
always cleaning tyre beads out after offroad trips.
Hi all I was wondering how often do you have to clean the beads on your tyres out. I'm asking this because every time I have been offroad I always had at least one tyre that got mud or rocks in the beads. It's becoming a pain in the butt and hassle.
edit: i run coopers st maxx and around 25psi
17th August 2014 08:31 PM
17th August 2014, 09:07 PM
Smart like tractor
What type of tyres and how much pressure do you run?
96 GQ coil/Cab
08 G6eT
17th August 2014, 09:14 PM
BIG & BALD
I have had the same problem with mine, I've been running 20psi on most trips.
I have run 18psi once which was suggested which left me with a lot of debris in the beads too.
17th August 2014, 09:36 PM
Yea I'm much the Same I run between 18- 25 depending on where I'm driving and it will happen more if driving in muddy rutted tracks, the only sure fire way to avoid it is beadlocks unfortunately, internal or external. I only clean them out if I get a slow leak.
17th August 2014, 10:27 PM
Hardcore
Yeah same here. I run 25 psi
Lucus30's 1999 GU ST TB45E
18th August 2014, 12:19 AM
I was like that before I got my km2s, since then, have not had 1 bead issue. I usually run around at about 20-25 while off road.
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
18th August 2014, 12:31 AM
I was wondering if it was the tyre but mick has km2 like you and I'm running mtz ATM.
18th August 2014, 01:28 AM
megatexture
I had Micky t atz's before and they were horrible. Every time I went off road, it was numerous dirty beads, tyre balances out, and a couple of punctures. I believe (no idea if it's true) that the more a tyre is taken of the rim, the bead stretches and doesn't seal as well. Until last week I had not had my km2s off the rim for any reason since fitting.
I think it also helps that that my km2s are bigger too, I've got 305s on a 8" rim, so they are snug. Steve has the same so it would be good to here from him.
18th August 2014, 09:02 AM
BIG & BALD
megatexture
Wombat has a good reputation of those little white pebbles getting into beads.
18th August 2014, 10:03 AM
I think it also depends on how hard you hit the ruts with the steering turned which will flex the bead off and filling it with mud.
I run 20 psi in my tyres and only needed to clean out the bead on one tyre after I slammed the car into a rut and a bank trying to climb a hill
