13th August 2014, 03:45 PM
Rear Aircon problem
Hi all! Been awhile since I've been here, but been a bit busy in the bush!
So the other day, came back from a great day out at Cape Kraudren, and as I'm unpacking the Trol, I see green liquid on the ground near rear left wheel. Upon closer inspection, it LOOKS like coolant (like radiator coolant) coming out of one of the pipes going from the front of the car to the rear Aircon unit (I have a GU3 ST-L). Now it appears the pipe was slightly 'squished' when my Long Range tank was installed (over 2 years ago!) and I suspect that is what caused the issue.
But WHY is there coolant in those pipes? I always thought it was Aircon GAS from the front system.
I haven't had time to play with it, but I've been driving to and from work without the air or heat on since and there is no more leak.
Thoughts? Easy fix? Can I 'just' cut out the bad section and replace with flex hose??? My mate (cruiser driver) swears I must have heat in the back too, but I can only run the rear system when the front Air is on.
Thanks all,
13th August 2014 03:45 PM
13th August 2014, 04:35 PM
mine only runs if the front AC is on. Fan or heat doesn't work. GU8
Would be handy if heat and fan did work. Possibly there's a way to re-wire it?
Patrol GU8, Manual, snorkel, steel bull bar, Simpson Ed
13th August 2014, 05:13 PM
Mine also only works with a/c on possibly it is air con gas with dye in it does the front a/c work
13th August 2014, 06:30 PM
Haven't tried yet. I will tonight and get back to you.
13th August 2014, 07:40 PM
Aircon 'gas' is a green oil like substance at atmospheric pressure.
It wasn't that?
14th August 2014, 07:50 AM
Ok, so ran AC last night, no go.
Rubber: yes, I think you're right. There is still an 'oily' residue left on the foam insulation wrapped around the pipes. So the pipes need to be fixed or replaced, AND I'll need a complete re-gas
So, is it possible to cut out the bad section and somehow fit a new piece in? I heard the replacement pipes are quite expensive from Nissan (as are most things). I know the re-gas alone will put a big hole in my back pocket, but hell, I live in the NorthWest, so I'll need my AC back SOON.
Any thoughts?
14th August 2014, 10:43 PM
I know exactly what you mean.. There are special joins you can use to fix a broken pipe however depending on where it is a new pipe may be required. The front and rear a/c use the same piping teed off just in front of the firewall. All a/c systems are filled with a green fluorescent dye these days and that's what you will have on the ground, electrically you need the front a/c on too use the back however the gas is all linked unfortunately
Qualified Auto-Electrician
Apprentice Sparky
Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
14th August 2014, 11:01 PM
Thanks mate! I'll hit up a couple connection places this week and see what they can do. I hope it's as simple as a new join at the back and then a re-gas. Anyone know how much pressure is in an AC system?
15th August 2014, 08:59 AM
Bad-Trol
Yer mate a Nissan patrol with duel a/c has 1kg of R134A refrigerant in the system
Fletcha
Apprentice Sparky
15th August 2014, 09:13 AM
Thanks for that! Shouldn't cost too much then.
