Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Bullant4x4 Rear Draws
    Aug 2014
    Lightbulb Bullant4x4 Rear Draws
    Just talked to a mate that can get me heaps of 16mm water resistant ply for free. So going to start the rear draws this week. Going to incorporate all electrics, compressor etc into it.
    Anything I should look out for or any hints or tips? It's for a GU 2013 wagon
    Tony
    330 Post(s)
    Good luck Tony, are you going to use proper slides? Have fun
    Aug 2014
    Was thinking of these.
    65 Centimeter 120 Kilogram rated Drawer slide
    One pair
    Specifically designed for external and industrial outdoor use
    Full extension
    65 Centimeter closed, 130 Centimeter extended length
    Multi roller bearing
    Locking mechanism
    Side mount
    http://m.ebay.com.au/itm?itemId=171248685057
    650 mm 120 Kg Heavy duty ball bearing fridge drawer slide runner locking 4WD
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    There is plenty of build threads on this subject, so if you do a search you will find heaps of tips.
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
  6. #5
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    16mm is a lot of dead weight.
    Cannot pick up 12mm..
    Your spanning 600mm, so you could easily hold a party on 12mm
    Aug 2014
    Quote Originally Posted by biggqwesty View Post
    Decided on 800mm long. I looked at the 12mm but seems flimsy. Also getting the ply for free, so it's a deal breaker :)
    Going to make a few and see which one I like the most. I pinched Cnut idea with the power panel and design.
  8. #7
    Expert Crate's Avatar
    Apr 2014
    Bonbeach
    Check out UES for the drawer slides and latches cheaper than ebay and better quality imo
    GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
  9. #8
    330 Post(s)
    12mm is plenty thick enough. I would build with 12mm and use a 15mm top and drawer bottoms only.
    I like the electric panel. Who's build is that from? Make sure you set it back far enough that you can plug stuff in and still close the door or you will smash stuff in the first day
    Line the inside of the drawers with carpet will help keep the load quiet.
  10. #9
    Aug 2014
    Full instructions and where he brought everything.
    http://www.4x4earth.com.au/forum/341108-post.html
  11. The Following User Says Thank You to Bullant4x4 For This Useful Post:
    MudRunnerTD (12th August 2014)
  12. #10
    Gold Coast
    2 Post(s)
    I have "Outback" drawers and part of the install instructions include drilling out one anchor nut and fitting a bolt, plates and washers. Its an ADR thing.
    GU IV 2006; 3.0 DDi ST-S; Nissan Snorkel, Bull Bar and Tow Bar; Warn 8,000# Winch with Dyneema rope; Auber EGT, Boost and dual Battery gauges; Provent 200; Dual Batteries; Three Dogs recovery points; Rear Springs +20% load; Outback drawers and Cargo Barrier; UHF; [GPS, Radio, CD, Bluetooth, SD, USB] floor extension; Alloy roof rack
    "Smart people know what they don't know"
