7th August 2014, 06:43 PM
Spot light and LED light bar install
Hi Guys
just purchased some HID spotties and LED light bar
Would I need to run 2 x relays ? I want individual switches for the spotties and individual switch for LED light bar ? is there a simple way ?
thanks in advance
7th August 2014 06:43 PM
7th August 2014, 06:49 PM
You will need 2 relays if you want to switch them separately,I find trailer wire good for this.one in off the high beam and then 2 going to the relays and you then have 2 or 4 wires left for later and all you had to do is run 1 wire through the fire wall .
