Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Lifting the Jayco Swan
    Nov 2013
    Gold Coast
    Love the concept.
    Do not like the weld across the drawbar extension section. Advice from engineers was to avoid cross welds rather better to locate welds along the tube sections. This certainly was proven when building chisel plow and similar ag box section style units.
    Kallen's point about extending the drawbar further back to intersect the underbody chasis members is also worth considering IMHO
    Chimo
  2. The Following 2 Users Say Thank You to Chimo For This Useful Post:
    Bigcol (24th November 2014), gaddy (6th October 2014)
    Patrol Freak gaddy's Avatar
    redlands
    Finally got around to mocking up the rear bar , just need to add some tie down points for Jerry's and paint , and fitted the drop jacks
  5. #23
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Quote Originally Posted by Chimo View Post
    Love the concept.
    Chimo
    its already been said - about making the draw bar go from under the chassis
    when we did a similar thing to my Father-in-laws Camper years ago, we used 75x50x4RHS
    started from behind the axle and went to the front - big long V shape - made it about 2m from front of the Van to the hitch
    as the chassis was sitting on that for over half the Van length, and was welded everywhere possibly known, he never had a problem with it.......
  6. The Following User Says Thank You to Bigcol For This Useful Post:
    gaddy (24th November 2014)
  7. #24
    redlands
    Yeah , I'm happy with it , the guy that will be doing the mod plate reckons more then strong enough due to the high tensile spring steel on edge under the draw bar , and runs from hitch back to past the new chassis , and the bracing behind the hitch box ,
