Results 1 to 10 of 11
Thread: ARB Bar with roller fairlead support bracket and swapping to dyneema rope
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Hi Guys, I've got a rope left over that I was planning to put on my GU before I left it behind. My question is really for my current Jack, but it is exactly the same on the ARB bar for the GQ I think?
    If I take off the old roller fairlead and swap for the hawse do you reckon the support bracket will get in the way (in terms of the rope rubbing on it)? I could take to it with the angle grinder, but don't know how I'd ever get the bar looking neat and tidy after I ground it off and in the process took most of the powder coat off?
    Maybe it's not an issue, but I'm worried on some odd angle one day I might rub the rope on the bracket. It will probably also look crap sitting out there on it's own. What do you think? Any suggestions? Anyone already tackled this on their GQ?
    The black one is my Jack, the other is the ARB photo for a GQ deluxe bar.
    Thanks, Cameron
    No Patrol now - Just good memories!
    Thomastown, Melbourne
    6 Post(s)
    Not at all ... I have the same set up and run rope and no problems at all....
  4. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    cgm (3rd June 2014)
    Jul 2012
    Ballarat
    Thanks BA, I'll put it on the list of things to be done then.
    Thanks, Cameron
    6 Post(s)
    You need the offset fairlead for that bar as the normal one does not line up..... Just double check before ordering.
  7. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    cgm (3rd June 2014)
  8. #5
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    If you are that worried about running a hawse fairlead you could always replace the rollers with nolathane/poly ones. They are meant to be rope friendly and would lookno different to it is now, except maybe a colour change from the steel rollers.
  9. The Following User Says Thank You to sooty_10 For This Useful Post:
    cgm (3rd June 2014)
  10. #6
    Jul 2012
    Ballarat
    I have the hawse already (bought it with the rope for the other bar), but I'll check it all carefully to see if it should be offset. I haven't noticed or heard of the nolathene/poly ones. So I'll go and search about those now.
    Thanks for the input guys.
    Thanks, Cameron
  11. #7
    Jul 2012
    Ballarat
    Quote Originally Posted by sooty_10 View Post
    ... you could always replace the rollers with nolathane/poly ones. They are meant to be rope friendly and would lookno different to it is now, except maybe a colour change from the steel rollers.
    I'd really never noticed these before.
    Here is an example. Will probably try and check the hawse one I already have simply for $$. But, if I'm not happy with it then this is definitely an option.
    http://www.ebay.com.au/itm/like/3011...=true&lpid=107
    Thanks again.
    Thanks, Cameron
  12. #8
    330 Post(s)
    I cut it off the one on the GQ on the old bar, came up very neat. It's all in my build thread. I'll see if I can find the post and direct you there.
  13. #9
    330 Post(s)
    Thanks guys,
    OK here is the next installment, there were lots of things i did in this build up that i took pics of and i will add in sections for your info.
    First one is the front bar and Winch
    Here is a pic the after i fitted it all back up and this is basically what it looked like before the strip down
    First i fitted up the Chrome Grill and was happy there.
    Then i had another look at the front bar and just thought that is was getting pretty grubby by comparison to the rest.
    I had to strip out the winch to fit the airlines anyway so here is what happened next. I am a sucker for punishment.
    Out comes the Winch and set aside for other work. Going to run Plasma rope that has been in the shed for 2 years so this bit is not required
    Off it comes
    Rubbed back and ready for paint (cheap pressure pack Saturn Black from Bunnings)
    Next got started on the winch. I pulled it to bits on the bench in the shed to give it a good clean out.
    I used this link for a great writeup and how to ==> http://www.pirate4x4.com/tech/billavista/8274/
    Then i went about renovating what needed to be done. I Painted the casing using a Charcoal Hammertone paint out of a can
    I tapped the casing to run Air lines to pressurise the case for Bog holes etc. You can see also that i used some of that PVC liquid tape on the terminals thinking that i could trim up the mess when dry => NO YOU CANT!!! so after this pic i went and got a very fine brush and neatened it up allot.
    I reckon it looks great.
    Mounted it back up into the newly painted bar and fitted the air lines
    See on the back of the numberplate i have fitted a white LED marker light that is switched with the winch isolation switch in the dash and lights up the winch whenever power is connected to it. F*#king awesome at night for winching.
    Attached my home made Nylon Fairlead and Bob's your Aunty.
    From this >>>>
    To this >>>>>
    Mounted up my Lightforce XGTs that i converted to HID and wound on the plasma and ready to go!!
    Sorry on the phone but here is the main post.
  14. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    cgm (4th June 2014), Clunk (4th June 2014)
  15. #10
    Jul 2012
    Ballarat
    As usual Darren, top answer! Thanks mate. I'll have to see if I'm brave (stupid) enough to cut it off - ha ha.
    I'll try and check the fairlead and how it looks and then can decide on the chop at any time. Appreciate you digging it out. I'd forgotten about it, but once you mentioned it I remember going through your whole thread once and seeing it. (I remember coz it was such a big job to get through it all - glad you picked it out for me could have spent another couple of months just finding it )
    Thanks, Cameron
  16. The Following User Says Thank You to cgm For This Useful Post:
    MudRunnerTD (4th June 2014)
