Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Steering wheel shimming between 80 to 100 KPH
    Jun 2014
    Wangaratta Vic
    Hi Guys,
    Wondering if anyone some ideas on wheel shimming, i have replace pivots bearings and shims, wheel bearings done and re adjusted, steering box adjusted, steering damper replace, off set castors bushes fitted to lower control arms, tyres were re- balance and they tell me they were ok, all that has in proved it, i am out of ideas now!!! HELP!!
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Tell us what mods you have lift , tyre size etc
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    61 Post(s)
    First thing to do is post up an introduction before asking for assistance, that gets everyone on side from the start mate
    Patrol Guru TimE's Avatar
    Canberra
    3 Post(s)
    Found this list of possibilties, may be of use
    Wheel balance
    Out of round tyres (as opposed to out of balance)
    Loose wheel bearings
    Insufficient castor
    Worn or urethane panhard bushes
    Worn drag link
    Adjustment of steering box
    Worn tie rod ends
    Cracked panhard mount at chassis
    Steering damper unserviceable
  6. #5
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Many 4WDs have this problem. The usual cause is tyre balance. Go to a tyre dealer that specialises in 4WD and truck tyres. Some of the balance machines are OK for passenger tyres but don't always work well on larger, wider and heavier tyres. If you can't find any in Wang - try Tower Tyres in Wodonga.
  7. #6
    brisbane
    Mines doing the same ATM from flogged out radius arm bushes (chassis end) but worn panhard bushes can give a similar feel in my experience.
  8. #7
    Nov 2010
    6 Post(s)
    Every time I have shimmy it's a flogged or starting to flog tie rod end, I go through the motions of checking everything to make sure but it's always the rod end.
    The pan hard bushes give a violent shaking when they go
  9. #8
    Jun 2014
    Wangaratta Vic
    Quote Originally Posted by liftlid View Post
    Thanks guys for all your suggestions,
    We own Y61 2006 TD42T with leaf springs, It has 265/75 R16, which had Coopers ST Maxs, but now running Toyo muds, has the standard 2inch lift, have done radius rod bushes, have done panard rod bushes too, i have taken couple times back to tyre power and they says balance was ok, i am think of going else where to see if they can help, i have check tie rod ends couple of times but can't get any movement out of them
  10. #9
    Aug 2011
    River Heads Q
    4 Post(s)
    I replaced front wheel bearings before this Cape trip and tightened them up just a fraction more than usual and they are perfect with no wobble at all.
    At the end of the day, all you have is yourself and all you need is your friends (and in our case our Patrol)
    2006 GUI1 4.2TDi Coil Cab "almost" standard
  11. #10
    Nov 2010
    6 Post(s)
    Try Swapping tyres ft to back see if it changed
