11th June 2011, 09:59 AM
#151
SPAMINATOR
toddrhind
Sorry Andy, didn't even think without the 25 post rule applying that none members couldn't download the pdf 2 get the manual, I should of asked first. Was 2 focused on why Peter couldn't access the manual on his mac
Me bad.
Thanks boss 4 removing them
I think you'd better sit in the corner and face the wall Todd tut tut tut
11th June 2011 09:59 AM
11th June 2011, 10:02 AM
#152
Rotaredom
growlers71gq
hahahahaha.......yeh that's probable a good idea *L*
15th June 2011, 12:58 PM
#153
The manual is exactly what I need. I have a GQ with 325,000klms & have just struck my first problem with the engine warning light. Could be that I have used E10 for the first time.
15th June 2011, 01:10 PM
#154
Administrator
GedB
Welcome to the forum mate, glad you found us.
Don't forget to put an intro about yourself and yoru rig in the introductions section and feel free to ask any questions mate.
15th June 2011, 06:08 PM
#155
Rotaredom
GedB
I have used E10 since it was introduced and never had a problem with the engine warning light
16th June 2011, 12:33 PM
#156
Hardcore
GedB
In some cars/situations the E10, due to its chemical make up, does not get combusted 100%, the left over fuel residue goes out the exhaust, and gets collected by the Catalytic Convertor, where it can slowly burn and destroy/block a Ceramic Cat in no time.
Later model cars designed to run E10 have metal core cats ,not the older ceramic type, cats with higher CPI (cells per sq inch) can be more susceptible to blockage.
Id stick to regular unleaded (what you car was designed to run on)
Check for a blocked Catalytic Converter, an easy way is, if you can unbolt the exhaust before the Cat to relieve the exhaust gas, then see if engine will rev or gets more power back.
If the Cat is the problem, the blocked exhaust will most likey have triggered a faulty O2 sensor/engine check light.
The Following User Says Thank You to 04OFF For This Useful Post:
NissanGQ4.2 (16th June 2011)
20th June 2011, 02:13 PM
#157
Howdy Ive tried opening the Manual byt all I can do is get to a page that says
Click below to download the GQ Nissan Patrol service manual
LINK REMOVED BY AB
but nothing happens?
20th June 2011, 02:14 PM
#158
20th June 2011, 02:52 PM
#159
Administrator
Crowman23
LINK REMOVED BY AB
Hi mate, I just removed that link so only members who sign up have access to it.
The file is 109mb but if you click on it, then it will be a blank page and can take some time to download depending on how fast your internet is.
You should be able to see at the bottom left of the page the status of it downloading....Example: 2mb of 109mb, etc...
The Following User Says Thank You to AB For This Useful Post:
Crowman23 (22nd June 2011)
22nd June 2011, 12:24 AM
#160
i have tried to open the link for the patrol manual but it does not open help!
