The Mount Co is a rubber suspension parts specialist based in Australia, with over 10 years experience in the automotive trade.
We choose to ONLY sell you rubber because that's what millions of kms of OEM research has worked out is best for your car. Essentially we believe that you should put in the same material as what you take out.
Being specialised in only one type of product, we can focus on delivering great expertise, excellent product quality, reliable and fast delivery and above all the most competitive prices.
Our range includes suspension, driveshaft components, strut mounts, engine mounts and more. We are a professional outfit with over 10 years experience in the automotive trade. Check out our specials below or visit our website for the full range: www.themountco.com.au
Nissan Patrol GQ/GU Front Suspension Arm Bush Kit (Rubber OEM replacement): http://www.themountco.com.au/patrol-brushes-front.html
This Front Suspension Arm (Standard) Bush Kit includes:
4 x OEM replacement rubber filled cylindrical castor bushes - for the diff
4 x OEM replacement rubber-chassis mount
2x STEEL REINFORCED rubber panhard rod bushes - for both sides of the leading radius arms &panhard rod
To Suit :
GQ Patrol 1988-1997
GU Patrol 1997-2/2000
GU Patrol All models (cab chassis)
which have Panhard Rods with two cylinderical bushes chassis end (small and large hole type)
$130 AUD >> BUY NOW ONLINE
Nissan Patrol GQ/GU 1988-2001 Front Sway Bar Bush Set (Rubber OEM replacement): http://www.themountco.com.au/patrol-sway-rubbers-front.html
This Front Sway Bar Bush Set is a Two Sway bar "D" Bush
To be fitted between the sway bar and Diff housing
2x Front sway bar rubber bushes (bar diameter 19-20mm)
To Suit:
GQ & GU Patrol Series 1 & 2 1988-2001
$22 AUD >> BUY NOW ONLINE
Nissan Patrol GU Y61 Front & Rear Sway Bar Link Assembly: http://www.themountco.com.au/patrol-f-and-r-sway-bar-link-kit.html
This Front & Rear Sway Bar Link Assembly is for 2 standard length sway bar mount links.
These are required for standard height and up to 2"50mm of suspension lift on the vehicle.
These links are designed and supplied with rubber bushes, made from high quality mild steel.
To Suit:
Patrol GU 1997-2008 Front & Rear
$95 AUD >> BUY NOW ONLINE
