Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: What the hell is it????
    Expert chester's Avatar
    Apr 2011
    Found this in Number 8 CYL after pulling the head off. It's steel about the size of your little finger nail, it's solid, round on one side and flat on the other and has broken away from something but the big question is WHAT!!!!!!
    Its a bit hard to see in the pic but will give you an idea.
    A GOOD MATE WILL BAIL YOU OUT OF JAIL, A BEST MATE WILL BE SITTING NEXT TO YOU SAYING YEP WE F**KED UP
    SUCH IS LIFE Maxhead's Avatar
    ACT
    don't know....end of a push rod?
    ________________________
    ______ 2017 D-Max _______
  4. The Following User Says Thank You to Maxhead For This Useful Post:
    chester (25th July 2014)
    Apr 2011
    Nah mate it's solid and everything is in good nick. It could have only come from the intake system to end up jammed between the head and the piston.
    Feb 2011
    Shed
    45 Post(s)
    Is it the end of a glow plug? Hard to see in the pic
    Feb 2011
    Shed
    45 Post(s)
    Don't worry just read 8cyl derrrr
    581 Post(s)
    Almost looks like the top of the aerial...lol
    Expert Hardyards's Avatar
    Townsville
    Also sorta looks like a soild rivet with the head broken off?
    2006 GUIV DX 4.2 TDI Ute, Bullbar with Warn winch, Narva round spotties, scrub bars and side steps, Snorkel, Dual Battery system, Waeco fridge, 2 x Narva spotties an 80W solor panel on roof, Custom tray, 3" Redback exhaust, Bluemax 2 - EGT/Boost Oil press/Temp and dual volt gauges, Lifted, front locked and fully loaded......
    If you can't stand behind our troops, feel free to stand in front of them!
  10. #8
    sunshinecoast
    yeah , it does look like a rivet . do you have a snorkel that has had rivets used to mount it or has rivets been used elsewhere in the air intake system ?
  11. #9
    581 Post(s)
    You haven't modified your airbox by chance Chester?
    As above with the rivets, seen a few modded pizza boxes using rivets to hold the intake elbow...
  12. #10
    Apr 2011
    I have but I didn't use any rivets. The only riverts in the system is to hold the snorkel to the A piller.
