Results 11 to 20 of 21
Thread: What the hell is it????
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Anything from the snorkel would need to get past the filter, if it has a hole in it I would be convinced it's the end of a pushrod
  2. The Following User Says Thank You to liftlid For This Useful Post:
    Bloodyaussie (25th July 2014)
    Expert Crate's Avatar
    Apr 2014
    Bonbeach
    x3 on the end of a pushrod!
    GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
  5. #13
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I'm guessing it would have to have an oil hole through it if it was a push rod?
    And yeah, how the hell could it get past the valve stem seal?
    Is there any chance it could have been sitting around the head and got knocked in when removing head?
    Hello from Under Down Under!
  6. #14
    Aug 2011
    North West Tas
    56 Post(s)
  7. #15
    49 Post(s)
    If its part of a pushrod wouldn't it have damaged a valve? What are the rest of the internals like, cam, valves, lifters.
  8. #16
    43 Post(s)
    Well I cant see it being any of the above as all that stuff is outside the air flow circuit.. The only thing inside the combustion chamber is spark or glow plug, or valves..
    My guess woukd be an casting dag of alloy..
    Have you tested magnetism?
    Used to get bits like this on my 350 chev troopy running dual fuel,
    Because the gas runs so hot it melted the holley and molten alloy would get trapped on top of the piston .
    making a terrible noise,,, most times it would pass through the system, hope this helps
  10. #18
    Expert chester's Avatar
    Apr 2011
    Nah mate it was sitting in the indent it made in the top of the piston.
    A GOOD MATE WILL BAIL YOU OUT OF JAIL, A BEST MATE WILL BE SITTING NEXT TO YOU SAYING YEP WE F**KED UP
  11. #19
    Apr 2011
    Yeah mate it sticks to a magnet. All the other parts are fine, the only way it could get into where it was is through the intake manifold. Ive check all the sensors in the throttle body all the plugs and injectors are all fine.
  12. #20
    Aug 2010
    adelaide
    could have dropped in when someone did a service on the spark plugs
    OH LEATHER IS NICE
